2003 Accord problems with door locks and dome light
Old May 15, 2010 | 01:38 PM
milescwright's Avatar
Default 2003 Accord problems with door locks and dome light
Okay, I'm new at this. All of a sudden my door locks stopped working properly (it will unlock the driver door and roll down the windows if I hold it, but won't unlock other doors. Also, the unlock/lock switch inside doesn't work).
Also have weird problem with dome. It works when car is running but it won't light up when entering the vehicle.....it will if I move the switch to the On position.
Any thoughts? Thanks in advance....m
Old May 23, 2010 | 09:46 AM
Question, does the dome light work when other doors open. If so then I'd check the door jam switch. If bad then that could also be causing the issue with the door locks...just an idea.
cgoff
Aug 17, 2013 01:17 AM
bdrumm
Oct 30, 2012 10:46 AM
eckhart
May 8, 2006 01:05 PM
