2003 Honda Accord Couple V6 EX-L Stalling at times
All,
I have a 2003 Honda Accord Couple V6 EX-L automatic with Navigation, now with 234K miles, that has stalled twice in the last 3 months. Each time I was driving below 30mph and suddenly the engine would would be off; I lost power steering capability. I had two repair events in my car about 3 months ago: 1. I had my transmission rebuilt. 2. I installed a car battery disconnect on my negative terminal. 3. I installed a new DVD player module in the trunck of my car to run the nagivation. Otherwise the car runs mostly well. I am still seeing some slippage in the transmission at in the lower gears (1/2), but this is mostly when the car is cold. Do anyone has any thoughts about this issue? Thanks alot in advance. |
The transmission slip sounds like a fluid/hydraulic issue.
Did the car seem like it lost power when it stalled? I'd look at the negative cable disconnect for the stalling issue. Stop by a parts store and have them scan for codes as well. |
Ok. The car did seem to lose power when it stalled. However, as soon as I stopped and tried starting it, it started right away on both occasions.
Maybe I willl replace the nagative cable disconnect. |
Can you make it stall by wiggling the key? Flaky ignition switches aren't unheard-of...
