2003 honda accord keyless door lock not working
Hello Everyone,
The keyless entry system does not work anymore in locking/unlocking the doors in my 2003 Honda accord EX. First I though it was the battery that has died, so I replaced the battery with a new CR1616 lithium battery. Still the keyless entry does not work. However, I can Lock/Unlock the doors manually and the power Locks work very well Please I need help to make the keyless door lock/unlock. |
Do you have a second remote to try keyless entry to eliminate an issue with your remote?
I tried with the spare key with remote that I have and it didn.t work.
I also tried reprogramming the remotes again and both didn't work. |
I have 97 accord and I've been having the same issue as you.
I believe it has something to do internally with the receiving module from the keyless fob I'm 99% sure that said module is either under the steering wheel or under the driver seat. |
The Transceiver is in the Driver's door panel. It is in Power Door Control units. But can this unit go bad?
I have also suspected that module but I have not b=seen it been changed. Does anyone know if this unit could be responsible? |
I honestly have no idea, I’m a bit fed up using my key so I’ll probably be ripping my door apart soon :cool:
