-   -   2004 accord (https://www.hondaaccordforum.com/forum/general-tech-help-7/2004-accord-56357/)
tom2004 Aug 26, 2013 07:06 PM
2004 accord
My center control panel and shifter not lighting up on my 2004 accord any ideas? please help
JimBlake Aug 27, 2013 06:41 AM
Have you looked for blown fuses?
Have you checked for burned-out bulbs? (If you mean the entire control panel, that's several bulbs & not likely they all burned out at the same time)
tom2004 Aug 27, 2013 08:27 AM
Don't know what fuse to check. also replaced the shifter bulb and that bulb lights up.
JimBlake Aug 27, 2013 10:21 AM
You can probably find in your owners manual, which fuse is for those lamps. I don't have a circuit drawing for 2004.
But if you replaced the one bulb and it lights up, then the fuse must be OK.
Now if it's true that multiple bulbs have burned out together, maybe it was caused by a voltage spike?? In that case, have your alternator & charging system checked.
