2004 accord v6. Please help identify noise
Please help identify source of noise heard as the car is braking. The noise is squeaking/grinding. You kind of have to listen close. This noise is driving me insane, and any help will be much appreciated.
well, the first thing you need to do is pull the wheels and do an brake inspection. i think you will find your answers after that.
Thanks for the reply, Jeff. Do you think its the brakes? Could you please elaborate? Thanks in advance.
was hard to hear anything in that video, my response is based off your original post of hearing the noise while braking...so, yes me thinks it be the brakes you need to check ;)
Agreed with Dr. D.
Hard to hear anything from the video and usually first thing to check would be the brakes for squeaking/grinding noises. Usually, it is the inner pad wearing out first before the outer pad; but, they are replaced as a set. |
