-   -   2004 Honda Accord subframe (https://www.hondaaccordforum.com/forum/general-tech-help-7/2004-honda-accord-subframe-66456/)
D23vorobey 01-26-2019 11:45 PM
Will a subframe from 4 cylinder Accord coupe fit on a 6 cylinder Accord coupe. If not will a subframe from a v6 sedan fit on a coupe.
poorman212 01-27-2019 05:35 AM
Front or rear?
For the front, looking at Honda parts websites: The four cyl will not work with a v6. Looking at the part numbers the v6 coupe and sedan do use the same one. I used the auto transmission when looking at all of this. So if you have a manual trans you will need to verify that they are the same.
shipo 01-27-2019 09:27 AM
​​​​​Like @poorman212 wrote, there is no interchange between 4-Cylinder and 6-Cylinder sub frames, however, there is interchange between sedan and coupe with the same engine.
D23vorobey 01-27-2019 11:44 AM
So if a sedan has the same engine as a coupe it would work on a coupe?
shipo 01-27-2019 12:17 PM
Affirmative.
D23vorobey 01-27-2019 01:17 PM
Does it matter if it’s a manual or auto?
The Toecutter 01-27-2019 01:59 PM
Maybe, but that would come down to the trans and engine mounts.
