-   -   2004 Washer Pump Replacement (https://www.hondaaccordforum.com/forum/general-tech-help-7/2004-washer-pump-replacement-38568/)
kylak99 Mar 5, 2011 11:51 AM
I have a 2004 Accord. The washer pump quit out of the blue.
I checked the fuzes but they were all good.
I was hoping I could get a description of where the pump is and how to get to it?
TexasHonda Mar 5, 2011 12:18 PM
It's not that easy. Here's what manual says.
1) Remove righter inner fender (20-211)
2) Disconnect washer tube and washer motor connector.
3) Remove clip, 3-bolts, and remove the washer reservoir
Pump is at base of reservoir
4) install in reverse.
I would suggest purchasing a Honda Shop Manual if you intend to DIY. Make sure you can hear the pump running on command. Some times the washer nozzles block preventing flow. Easily cleaned w/ small wire and vinegar soak.
kylak99 Mar 6, 2011 09:26 AM
Thanks for the feedback.
There is no pump sound actually. Just the sound of the wiper motor now.
This sounds like a job I may just take to the shop.
WheelBrokerAng Mar 9, 2011 11:56 AM
Good job to tackle to get into the swing of easier jobs to come to you and your car.
Give it a try if you have the time..it's very satisfying when you get it done to say " I did It MYSELF" :)
Jared Festner Mar 29, 2011 02:25 PM
new question
just a minute
Jared Festner Mar 29, 2011 02:27 PM
same washer problem/ Jared Festner
Hey guys, My name is Jared Festner here in Illinois and I'm having the same problem. Although, It's been pretty cold here in Boulder Hill. Could that be why mine quit?
JimBlake Mar 29, 2011 03:15 PM
Did the pump quit? Have you ruled out plugged nozzles? Is yours also 2004?
Jared Festner Mar 29, 2011 03:22 PM
what's up man
This isn't Jim Blake class of 1999 is it? Jim, do you remember me? Jared Festner. Durand High school?
JimBlake Mar 29, 2011 09:18 PM
Just a couple years off... Class of 74 SMHS.
Jared Festner Apr 4, 2011 02:16 PM
sorry, I thought you were an old friend of mine. Yes, I've lived in Illinois my whole life and have never had an issue with my pump in the cold weather. Could it just be old? or Fixable?
