2005 accord dash lights and headlights
When I turn on headlights dash lights go out, when I turn headlights off dash lights come on, any ideas,,am new here
I would check the ground. I have no idea where it is on an Accord.
Originally Posted by Corvair
(Post 363931)
Has this car been in an accident or any work done on the car recently?
I'd start with where the headlights ground to the body. This is going to be below the headlights on each side. The diagram in the shop manual I have (thank redbull) is not clear if the bumper would need to be removed. I'd disconnect the battery. You will have to follow the wire harness near the headlights to where it branches with a several black wires to a bolt on the body. Unbolt those grounds. Clean the eyelet and bolt with a wire brush or sandpaper. Then reattach. Clean the battery cable and posts while you are at it. |
Originally Posted by PAhonda
(Post 363970)
