2005 Accord Hybrid Brake rotors
Hello all,
I'm looking to change the brake pads/rotors on my '05 Accord Hybrid, and install new Centric rotors all around. The issue is that I cannot seem to find the correct part number for the '05 Hybrid; depending on the website I go on, it often gives me a different answer as to which the right rotor size is. The Centric catalog itself gives some extremely confusing and contradictory information and is of very little help. The Centric rotor numbers that most sites' part finders give me varies between 120.40036 and 120.40046 for the FRONT rotors. For the REAR, most say part #120.40068. Can anyone confirm which of these Centric part numbers are correct for the '05 Hybrid? Or if you do not know specifically about the Centric parts, does anyone know if the 7th Gen Hybrid Accords used brake rotors that were a DIFFERENT size from the rest of the Accord fleet? Because if they are all the same, I'll just order the same size that the standard V6 sedan uses. Thanks |
Only thing I can say is very with the OE PN 45251-TA0-A01 (front) and 42510-SFY-000 (rear)
4-door Hybrid Front = 45251-TA0-A01
4-door EX-V6 Front = 45251-TA5-A00 4-door EX-4cyl Front = 45251-TA0-A01 or 45251-TA5-A00 4-door Hybrid Rear = 42510-SFY-000 4-door EX-V6 Rear = 42510-SDA-A00 4-door EX-4cyl Rear = 42510-SDA-A00 For the non-hybrids, I choose the 49-state automatic-trans versions. Then I got too lazy to look at ALL the other combinations. Try (for example) Majestic at: www(dot)hondaautomotiveparts(dot)com They seem to use Honda part numbers, but there isn't any indication what makes the parts interchangeable or not. The EX-4cyl seems to use either part but I have no clue why? |
Jim,
Since the Hybrid only came with a 6 cyl listing anything that has to do with the 4 cyl is out...just confusing things more.....you will have to admit that "most" of the time brake set-up on a 4 cyl and 6 are/can be different. |
Yeah, but when I saw the EX-V6 has a different part number I started looking at other versions of the car. I was surprised to see the EX-4cyl having 2 different part numbers listed and one of those was the same as the Hybrid.
The listing of both part numbers on the EX-4cyl seems to say that you can use either one. So I don't know why the others list only one? |
