2005 Honda Accord EX
I have a 2005 Honda Accord EX my GPS screen went out and now my cruise control radio sunroof and my horn are not working my my panel is not working so I cannot engage my AC button and it is hot as I live in Arizona someone please help thanks
thats one of those issue you will probably need to take it to honda.
I'm going to move this to General Tech where you're more likely to get something. The "New Member" area is mostly for welcome & introductions.
I don't have wiring diagrams to know whether all those things come down to the same fuse or to the same ground point. That's my first thought for how to track it down. |
Check the battery. My navigation was going in and out I could not figure it out then finally it died. Then other things started to go out. I changed my alternator and it was not my problem. I then decided to change my battery. I decided to go with the v6 size battery because I have had issues with my battery since I pulled it off the lot in 06 and I thought it may be a grounding issue too. To go up in size with the battery I had to purchase the v6 battery crate and grounding cable (thicker gauge). Once I changed everything out and filed the paint from the body connection point for the grounding cable I have had no more issues. I have had issues with my battery since I bought my car in 06 and it is an 07 accord. It's been a year strong and no issues.
