2006 Accord 2.4 p0139 2006?
Old Feb 27, 2016 | 11:49 AM
Milooo's Avatar
idle is about 720 to 850 rpm. its stick shift
Old Feb 27, 2016 | 12:07 PM
Milooo's Avatar
ok, checked stlt trim again at idle. now it is st like 10.2 at idle lt is like 5.5 idle was 725.
Old Mar 1, 2016 | 02:32 PM
Milooo's Avatar
Anyone???????????? Hello????????
Old Mar 1, 2016 | 03:42 PM
Dr. Drivability's Avatar
So you've verified that the ECM/PCM has been flashed with the latest program?
Old Mar 1, 2016 | 03:56 PM
Milooo's Avatar
yes. what about my stlt trims???
Old Mar 1, 2016 | 04:09 PM
I'm not worried about the fuel trims right now, but that bosch sensor is junk...we get more techs that won't listen us. Use a Denso sensor, and california and non-california are different sensors as well.
Old Mar 1, 2016 | 04:14 PM
  #17
Milooo's Avatar
bosch sensors are good and as good as denso.
Old Mar 1, 2016 | 06:20 PM
  #18
Your fuel trims look good, so the engine computer is not having to add or remove a lot of fuel due to the a/f reading.
Is there a certain rpm where the CEL turns on?
Old Mar 1, 2016 | 08:23 PM
  #19
Milooo's Avatar
not that i noticed. i changed the air fuel sensor so will see what happens, so far so good
Old Mar 19, 2016 | 11:38 AM
  #20
Milooo's Avatar
well it has been at least 3 weeks and 600 plus miles since i changed the front air fuel sensor and i have NOT got a check engine light back yet. I am sure since I am posting this it will pop back on now but I think this fixed the problem.
