Sponsored by:
Sponsored by:
Hello every body Im a new member, Need a Little help plz.
Old 10-24-2012, 03:10 PM
vip001's Avatar
Default Hello every body Im a new member, Need a Little help plz.
i got a problem in my 2007 accord, Headlights problem i turn the high beam on but when i turn it off the headlights still turning on, I have to disconnect the bulb from the engine to turn it off .
Old 10-24-2012, 03:26 PM
Dr. Drivability's Avatar
from what i can gather from your explaination, the circuit uses a control module and a high and low headlamp relay. i'd suspect a relay sticking on.
Old 10-24-2012, 04:13 PM
vip001's Avatar
thanks for your help.
Old 10-24-2012, 05:15 PM
vip001's Avatar
Default Help with installing new HID kit
Just installed new Bosch hid xenon on my 2007 accord with low beam lamps, The problem is when i turn the low beam on the fuses of low beam go down.
i checked up the hid kid with another car and its working fine but on my accord when i turn the headlights on the low beam fuses just damage.i changed the fuses but the problem still exist.
note:when i remove the new HID and return the factory one the problem is gone.
Old 10-25-2012, 07:45 PM
I've merged these together and as such they may not be "in order"....Dr responded without seeing the next post.....
RedChops
04-16-2013 04:30 PM
JC8643
10-22-2012 09:42 PM
blkboyan1486
07-17-2012 06:51 PM
rg2415
04-06-2012 10:43 PM
Edinburger
03-09-2006 01:05 AM
Quick Reply: Hello every body Im a new member, Need a Little help plz.
