2007 4dr EX - Driver door lock - Help diagnose
Hello everyone and thanks in advance for the help. My 2007 Honda Accord, at 140,000 miles, is having some performance issues in the door locking and unlocking category. Please help me determine what I need to repair/replace and if I can handle it without taking it to a professional. Symptoms:
Thanks for your help! |
I'd change the battery on the key fob just to be thorough.
Does the fob work to unlock and pop open the trunk? How do the locks behave when using the passenger door lock/unlock switch ? |
I'll give changing the fob battery and using the passenger door a shot tomorrow.
The fob does work to unlock and pop the trunk. |
Your description of the issues doesn't point to one component in the system.
The fob works by sending a signal to the fob antenna built into the driver's door switch. All driver door inputs (fob, key, lock/unlock switch) are sent from the driver's door switch digitally through a network wire to the MICU (multiplex integrated control unit in the driver's fuse box). The MICU powers the lock actuators depending on the input. The passenger and other door inputs are sent direct connections to the MICU. Since the passenger and rear doors lock/unlock the MICU is able to send enough power to the actuators if it gets the correct signal. I like to test as much as possible before replacing a part. You could have a bad driver's door switch. The wiring from the driver's door that goes through the rubber boot into the body can have some damage. The wiring can have issues due to wires bending when opening/closing the door, or somehow you are not getting enough voltage to the driver's door switch. The MICU is also a possibility as well. We can give you some tests that would require a test light or a volt meter to avoid replacing a properly working part, where you would check for good power and grounds at the driver's door switch and pull the driver's panel to test at the actuator connector. It depends on how much you want to test before replacing a part. |
Originally Posted by PAhonda
(Post 400454)
Thanks for the continued support! |
| All times are GMT -5. The time now is 06:07 AM. |
