2007 Honda accord EX Radio not working
2007 Honda accord EX radio won't turns on, AC works fine, only no any sign of light (power) to the radio. Checked all the fuse individually under the dash and hood, everything's are fine. Need help please.
No any electrical job done in the car recently. thanks, |
Have you disconnected the battery or lost power? After power loss my '09 requires me to put in the radio code for it to work again but I get a readout telling me to do so. It's like a five digit code or something forget the exact requirement.
Originally Posted by dgp1961
(Post 384535)
Thanks for the suggestion, I did disconnect the battery for about 5-7 minutes , still no sign of power . |
You could remove radio and confirm battery power is present at radio connector. If power available low cost fix is used identical radio or aftermarket.
good luck |
These radios go out all the time. If you're not good at soldering purchase a second hand one. I had to fix mine a few years ago then sold it for the Navi one since those were more reliable.
