2008 Accord Sluggish Power Window
My 2008 Accord EX 2.4 L has a problem with front passenger power window. Using either the passenger window switch or the driver's master switch, I can lower the passenger window. But when I try to raise it again it goes halfway up - then gets very sluggish - then the window reverses and goes back down. Any ideas ?
Sounds like the channels are in need of cleaning and re-lube. Once the window "sees" enough resistance it goes back down-so you don't roll up the window on your arm or head- safety feature....'08 might still be under warranty??
