2010 accord locksmith misbehaving
hi all
Last winter, I had an intermittent problem with my rear driver door not locking when I️ used my remote to lock. Happened a few times a week. Never did anything to fix because it stopped the behavior by spring. It’s been fine since. This week it started the same weird behavior but on the front passenger door. Took it to Honda today and the guy looked at me like I️ was making it up. They were too busy to look at it so thought I’d check here. You guys give better guidance anyway. When the car hits 20 mph the doors all still lock. Most of the time the interior power lock buttons lock all doors also. A couple times those buttons didn’t lock which ever door was misbehaving at the time. Anyone else have this problem Andy know how to fix? |
No one has any ideas?
I never had this problem. If the problem door is changing, I'd suspect something with the driver's door switch or the wiring nearby. It is possible that you have failing actuators on several doors.
You would probably need to verify that the actuator is getting voltage and ground when it is misbehaving. |
