2010 honda accord
Old Jan 13, 2018 | 08:52 AM
PELLEY's Avatar
Default 2010 honda accord
my 2010 has no heat on drivers side and lots on passenger side. plenty of air though
Old Jan 13, 2018 | 10:00 AM
The heater core may be partially clogged. See this thread:
https://www.hondaaccordforum.com/for...rs-side-60908/
Old Jan 14, 2018 | 09:25 AM
Got dual temperature control?
I don't know how the 2010 is setup, but I'm pretty sure there's only 1 heater core. What about the air-blend door not working for the driver's side?
Old Jan 15, 2018 | 04:12 PM
PELLEY's Avatar
will try a core flush... have examined the blending motor and replaced with a new one ...still the same. what product should i use to flush core. thank-you for your response
Old Jan 15, 2018 | 07:44 PM
PELLEY's Avatar
Default heater info
Is there any other device between the blending valve and the heater core which could effect the temperature supply on the drivers side
Old Jan 15, 2018 | 08:41 PM
You would have to disconnect the heater hoses, then flush with water from a garden hose. There are some youtube videos on that. I think Ericthecarguy did one.
You never answered this question. Does your car have the option where you can set the driver's side and passenger's side to different temperatures?
Old Jan 16, 2018 | 11:40 AM
PELLEY's Avatar
yes there are duel temp. control
Old Jan 16, 2018 | 12:23 PM
It is possible that the blend motor or blend door is not working on the driver's side of the vehicle.
Old Jan 17, 2018 | 05:16 AM
PELLEY's Avatar
Did a core flush and still the same. The motor controlled by the temperature controller for drivers side is new and working fine but after a closer look, less air flow is on the drivers side as well as no heating. The air flow is less on defrost, front and foot well. wondering if a operation and diagram of the heater is available. thank-you for your help, very much appreciated
Old Jan 17, 2018 | 11:44 AM
Has the cabin air filter been changed recently? A clogged filter could restrict air flow through the heating system.
