2013 Accord, Automatic transmission Filter
What is the recommended interval of replacing AT Filter? For this model ATF needs to be drained and refilled every 30k, but I couldn't find any info on the filter.
Help is much appreciated. Thanks |
There is no serviceable filter.
1. Is this a 4 or 6 cylinder?
Four cylinder Accord came with CVT, while six cylinder Accord came with AT. Both have a serviceable filter; however, they are not considered a normal maintenance item. It is considered a lifetime filter; but, changed if it is leaking, contaminated, or when the transmission is overhauled or replaced with a remanufactured unit. 2. 2013 Accord 4 cylinder with CVT has a serviceable filter under the transmission warmer unit. #2 in parts diagram. https://www.hondapartsnow.com/resour...BC40CDD36E723F 3. 2003 Accord 6 cylinder with AT has a serviceable external filter. #6 in parts diagram. https://www.hondapartsnow.com/resour...7FE7139A1CB866 |
Very nice and informative. Thanks to you both for getting back to me. Saved me a call to the dealer service department and I am sure they wouldn't be that descriptive. About the filter - will not change it then, but don't like the lifetime idea when it comes to oil/fluids.
