2013 Honda Accord Flasher Relay location
Anyone know where the Flasher relay for turn signals is located? We checked the fuse box under the drivers side dash. Couldnt find it like earlier models. Anyone have a picture?
Your car is still under warranty, so you should just take it back to the dealership.
The location of the fuse boxes should be in the owners manual. I am not familiar with the 2013 accords. |
Were you able to find out where the relay is if it even exists? I'm looking for the same.
doesn't have a replaceable relay according to diagrams. just has a "relay sounder" built into the cluster to give you the clicking noise, and the control is built into the drivers side MICU usually located on the back of the fuse panel.
Relay sounder
Is there any way to disable that noise? I added LED turn signals to my tail lights and some load resistors to fix the hyperflashing, but when replacing my front turn signals with LEDs, adding 2 more load resistors did nothing. So I am trying to figure out how to fix it, and getting rid of the annoying clicking would be great.
A relay sounder??
Didn't think the 9th generation had the clicking sound... mine does not |
