2014 Accord EX Sedan CVT fluid
Old Nov 23, 2015 | 04:14 PM
MichaelT1960's Avatar
Default 2014 Accord EX Sedan CVT fluid
I recently drained the CVT fluid with the car on jack stands....
As per manual I added 3.6 quarts and started up the car to run thru all
shift ranges. I shut off engine and opened check bolt. A small splash of
fluid came out but it did not continuously slow drip!
I added all 4 quarts and still no slow drip! Is it because the fluid is cold or do
I need to add more?
Any Honda mechanics out there?
Thanks,
Michael
Old Dec 12, 2019 | 08:57 AM
Icthelite's Avatar
When you added the remaining .4 did you run through the gears again? Everything I 'e read so far indicates that it would be necessary to do so.
Old Jan 13, 2024 | 02:44 PM
aaciii@yahoo.com's Avatar
Default I have the same issue.
Same issue - more than 4 quarts came out when i drained my 2014 accord transmission. It filled a gallon milk jug, with a tad more left over!
i assumed whoever last changed the fluid (dealer) must have over-filled it. However, i have put 4 full quarts in and it is still not dripping out of the check plug hole!
this CVT definitely has a capacity greater than 3.7 quarts based on this.
rickslick
Dec 26, 2019 01:09 PM
rponfick
Dec 12, 2019 01:53 PM
1staccord
Dec 12, 2019 09:02 AM
pinehilljoe
Dec 29, 2017 06:24 PM
denmick
Sep 2, 2014 11:18 AM
