6 speed conversion
Ok i have a 99 accord v6, i know it has ALOT more potential if i dropped a six speed in it, problem is, i'm not sure what tranny will fit the j30
its an easy swap, the holes for the clutch lines are already punched through the firewall, becasue they offer a 5 speed on the 4 cylinder, just got to jack it up remove some pieces and drop it downput new one in, clutch pedal, shifter and put everything back together |
RE: 6 speed conversion
Not as easy as you think. Many more parts than you listed.The 6 speed from a CL or TL will fit. There's a thread about it over on the6thgen accord website. For the parts alone, it will cost you around $5k (probably more).
here you go: http://www.6thgenaccord.com/forums/s...ght=speed+swap |
