87 front turn signal/running lamps
Hello,
Did 87 accord models w/hideaway headlights have dual filament front turn signal lamps? My headlights work just fine but the "park" lights are not illuminated. The turn signals work fine. Thanks! |
RE: 87 front turn signal/running lamps
The sidemarker lights beside the headlights have 2 small "peanut" bulbs in them. To remove them; you'll need to use the switch on the dash to flip up the headlights, then you can see 2 screws that hold the side marker in, remove the screws and pull the assy, straight forward.
