-   -   91 Accord Starting issues (https://www.hondaaccordforum.com/forum/general-tech-help-7/91-accord-starting-issues-53697/)
philipherklotz Mar 18, 2013 03:31 PM
My 91 accord at start up runs like the spark plugs are connected wrong then goes normal after 20 seconds
poorman212 Mar 19, 2013 06:19 PM
I moved this from the post you put it in....
Does this seem to happen after sitting for a long period of time (say more than 3 hours). Or does it happen everytime you start the car?
Are you having to add coolant over time?
philipherklotz Mar 20, 2013 05:40 AM
It happens evrry morning after parked 5+ hours
philipherklotz Mar 20, 2013 05:48 AM
No just started doing it after i had the front subframe replaced never had anything like this yesterday it happend in A.M. n 10 sec later everyhing fine i put gas in tank only had about 2-3 gallons n added a injector cleaner concentrate and 3 gallons and it did it again then it hasnt since the last 24+ hours. The coolant is fine does leak i check it however month an half ago it was bone dry cause a hose busted so i replacd and filld it it went hot i chkd again and it was empty or 1/2 full added fluid and has been ok
philipherklotz Mar 20, 2013 05:51 AM
My oil though seems to split a bit quick and my gauge by speedo is red for service
poorman212 Mar 22, 2013 08:52 AM
If the car has sat for a period of time then it could be the gas.
With fresh gas and the cleaner, if the issue doesn't come back...call it good.
If it does come back, let us know.
tn6fshn Mar 24, 2013 11:59 AM
the car turns over fine, wants to start but just wont???
