91 Honda Accord EX 4-cyl
We drove 200 miles 2 days ago and this car purred like a kitten. This past year we had the timing belt, water pump, speed control sensor, Front Rotors and Battery replaced. This morning I tried to start the car and nothing happened. This evening my husband checked the battery and it is Good. What could be the problem? When I turned the Key it doesn't do anything.
Can you provide a little more detail.
When you turn the key to the II position, does the gauge cluster do the bulb checks. When you turn the key to start, I am guessing that nothing happens? |
When I turn the key to II position the charging system lite, Seatbelt lite, oil pressure lite and Brake lite turn red in the gauge cluster. When I turn it to III the Green S lites up also. No noise or nothing except for the seat belt beeper when I turn the Key to Start.
On top of the gen tech help, there is a common diy index thread. There is a link to checking for engine codes. Count the check engine light flashes and the S light flashes. Let us know what you find.
