92 Accord Ex aftermarket BBK and hub assembly identification.
4 Attachment(s)
My 92 Accord EX 5 speed with ABS and 4 wheel discs has some upgraded or traded parts that I or Napa can not identify. The car came with two wheel bearings and I soon realized that it was because they only lasted about 2000 miles. After ordering a new hub assembly I realized none of it is stock. I have attached some pictures hoping that someone will recognize a common upgrade or swap. I've been all over the internet trying to figure this out and I'm lost. Thanks for any and all help.
Attachment 16979 Attachment 16980 Attachment 16981 Attachment 16982 |
That looks like the stock knuckle, so I will guess that the previous owner did the rotor over the hub conversion. The hub will be from a 98 or 99 Acura CL. The bearing should be the same bearing for your car. You can have the hub pressed out of the the bad bearing and into the new bearing.
Here is a thread with the information. https://www.hondaaccordforum.com/for...nversion-3151/ |
