-   -   92 No Start (https://www.hondaaccordforum.com/forum/general-tech-help-7/92-no-start-18713/)
wietgr May 27, 2008 07:18 PM
92 No Start
'92 LX 2.2L Auto
- Stalled while driving and will not restart. I checked for spark a each plug and there was no spark to any cylinder. I checked for spark at the wire from the coil to the distributor cap and found none. So im thinking that it may be the ignition coil... I just wanted to see if anyone had any other ideas before I go dropin $$$ ona newcoil. Thanks...
-Greg
hondadude May 27, 2008 07:42 PM
RE: 92 No Start
Be sure you have power at the coil Black/yellow wire with the key on.
That proves the voltage is going thru the ignition switch.
In the DIY section Desert Honda has posted a quick check that can be done with a test light to prove Coil or Ignitor
