'92 Power lock issues
So my 92 has power locks and they function... sort of. The driver and rear passenger work properly. however, with you flip the switch the motors for the locks in the passenger and rear driver doors whine and the locks do not engage (or disengage) . Sound like they want to work, but something in those two doors is broken... want to add that the switch to activate all the locks works on the passenger door aswell. And all the locks work just have to be manually pushed up and down.
Is this a simple fix? And on that, can anyone reccomend a good keyless entry system that can be put on this model? Never done it before so if its too technical I'll wait. |
See following thread
https://www.hondaaccordforum.com/for...cycling-48713/ No, it is not a simple repair as access or removal of door lock can be challenging. It's w/i capability of any determined DIY'r. Takes a bit of persistence, but nothing special skill wise. good luck |
| All times are GMT -5. The time now is 05:11 AM. |
