93 accord automatic transmission sound?
Old Nov 12, 2008 | 10:45 AM
will93's Avatar
Default 93 accord automatic transmission sound?
We have a security guard at work that monitors our parking garage in the AM. Today he told me my car was making a humming sound and that he had a Honda that did same, then his tranmission went out.
On the drive home today I tried to pay close attention. What I do hear is a higher pitched "whirring" (hard to describe) sound thats most noticeable in 1st and 2nd gear and when the car downshifts in those gears. Car shifts OK.
Is that a sound that may indicate a problem is looming?
THanks
Old Nov 12, 2008 | 07:53 PM
hondadude's Avatar
Default RE: 93 accord automatic transmission sound?
I would suggest you change the trans fluid; if at all possible, catch the old fluid in to a shallow pan.
Then use a strong flashlight to look for 'glitter' in the old fluid.
Old Nov 13, 2008 | 07:00 AM
will93's Avatar
Thanks, I will do that. I will assume glitter=bad. If so, what then?
Old Nov 15, 2008 | 05:12 AM
If the fluid is glittery, start saving for a tranny repair. Then try changing the fluid a couple more times.
Use real Honda auto-tranny fluid - it seems to make a difference.
Only about 1/3 to 1/2 of the fluid drains out. So if it IS dirty, you have to drive aroundto mix it up, then change it again.
cat2115
Apr 26, 2014 07:49 AM
swingkid50
May 20, 2012 09:29 PM
Ronnie101
Jun 21, 2007 09:44 PM
Mike Diaz
Mar 20, 2006 11:23 PM
86accordlxi
Nov 13, 2005 04:09 AM
