93 Accord LX passenger side mirror help
Trying to replace the cracked PASSENGER side mirror on my Honda Accord, but i am having no luck at all.
I found a nice one today at the J yard, but in the process of putting in on, i cracked this one also. It it a power mirror, and i can see how the 2 springy looking white pieces go into the respective holes, but the round part will not slide on properly. I was getting part of it in place , and then i applied too much pressure, and CRACK! Has anyone mastered this replacement, and if so, can you share any tips you can give me. I assume this mirror can be replaced with the mirror body still attached to the car?, or does it have it have to be removed. Any guidance would be greatly appreciated. |
Are you replacing just the glass?
(Post 364166)
Yes, the housing is still intact. Now, i have 2 cracked mirrors, and 1 mirror with no casing around it. Is it possible to get 1 of the broken mirrors out of the enclosed plastic casing it is in, and fit this mirror (uncracked) into 1 of them? Does the entire assembly need to be pulled off, or is there someway to get a new glass on it? I understand where the 2 plastic pieces fit, but the round piece on the back of the mirror will not seem to attach to the white round piece that is affixed to the assembly. |
2 Attachment(s)
I don't have experience with this type of repair. Here is the page from a shop manual that may help.
Thank you for the diagram, i will try it next time i find another mirror to use.
An entire mirror assy is fairly inexpensive; check ebay and amazon. Very simple repair.
good luck |
| All times are GMT -5. The time now is 03:34 AM. |
