94’ Honda Accord Ex won’t start
I have a 94’ Honda Accord Ex that won’t start. I put a new battery in it. The dash lights work and all the outside lights work as well. It won’t turn over or crank. I checked all the fuses but all are good. When I go to start it, all the lights come on and the door beeping comes on but no others sounds at all. I need help as soon as possible if anyone can give some insight. Thank you and all help is much appreciated!!
When I turn the key all the way over, no sound motor doesn’t turn over, nothing. I hear the fuel pump engage. I checked all the fuses and relays and all of them are getting power. Could it be the starter or the ignition switch? It ran and drove just fine then sat through winter and now won’t start.
Starter issue
Commonly with old Chevys we used to smack it with a small hammer to release the bendix springs inside. Sometimes it worked most often it did not. We also had a solinoid which would push out the starter wheel and it's the starter that spins the wheel. Typically I turn the headlights on then try to start it. I don't know if anyone is familiar with this technique But I often use it to determine if the starter is functioning or how well because sometimes it's hard to get at it and jump start it.. If you have a problem with the starter let's say it's bound up on the flywheel and cannot turn your headlights will dim drastically. If the starter relay, the soliniod or the starter lost connection no dimming of headlights. Most common noise I hear is a rapid clicking which is the soliniod trying to kick out the wheel and the starter does not engage until this wheel is fully extended. Since you apparently are not hearing any noises it's usually one of three things, the starter relay, the solinoid or the neutral safety switch.
With Hondas it's often the motor brushes are worn down just barely enough to lose contact. Hit it while someone is turning the key - that works a few times but buys enough time to either get a starter or get parts to repair it. I don't remember which years are easy or difficult to get those parts.
maso5219
12-05-2015 09:09 AM
Sheri6889
06-17-2015 08:19 AM
txredrage
01-08-2014 10:52 AM
