94 accord dies when headlight turned on
Old Sep 25, 2013 | 05:20 PM
Slidesquad240's Avatar
Default 94 accord dies when headlight turned on
I was driving my accord when I noticed my radio cutting out a few times then the speedo went crazy jumping high then lower. I went to turn the headlights on and the car almost died? This just happened not sure why could it be a bad alternator? Thanks
Old Sep 25, 2013 | 08:29 PM
I would disconnect the battery and clean all ends of both battery cables with a wire brush or a piece of sand paper.
Then reattach. Stop by a parts store. They will check the battery/alternator for free.
Old Sep 25, 2013 | 10:39 PM
I'm gonna do that idk if my cars gonna make it to the store kinda dont wanna risk it
Old Sep 29, 2013 | 02:46 AM
Honda-Master's Avatar
i would first do as pahonda suggested +have the charging system tested,,,,,, yes it could be a bad alternator
Old Oct 16, 2013 | 07:32 PM
Alternator was bad. Replaced it had it checked battery and new alt are good. Today it started doing the same symptoms with the radio. I did notice my battery is a little wet on top would that get on terminals and cause this?
Old Oct 16, 2013 | 09:09 PM
94ex915's Avatar
Almost A Senior Member
Does your radio cut out only when the volume is loud?
Old Oct 17, 2013 | 06:07 AM
Yeah that's only when I notice it atleast
Old Oct 17, 2013 | 09:09 AM
I do have a system in the car
Old Oct 17, 2013 | 04:10 PM
94ex915's Avatar
My old car used to have this problem. Put a brand new battery and alternator and the problem continued. On my accord the previous owner wired the stereo to the battery to supply it with enough power. I think when the stereo turns off like that its protecting itself.
Old Oct 18, 2013 | 06:42 AM
Hmm if that was the case with mine I feel like that would of happened since I bought the car? Maybe I'm wrong but it is a new problem
