94 Accord Electrical... something weird going on here
Hey guys... have you ever seen this happen?
Seems like all the electric on the driver's side has a mind of its own. When I bought my Accord, it had a little front end damage (broken headlight housing, corner light, grill). The low beams werent working so I check them out, finding that the previous owner had patched the broken ground wire from the driver's side low beam. I took out that extra piece of wire and re-grounded it to a different location. Also, prior to my re-grounding, I noticed that the driver's side tail light would go out, then come back on later... so does the driver side front corner light and front park lights (in bumper). I noticed that the windshield wiper fuse was missing, I replaced that... everything was fine at first then the wipers would turn on by themselves. If I play with the wiper switch for a minute they'll turn off but come back on in a matter or minutes so I took the fuse back out. Any ideas? May be a bad ground somewhere? Thanks in advance for the feedback! |
1 Attachment(s)
Start out by replacing the wiper switch and see if that was the only problem your haveing...
WheelBrokerAng :) |
Thanks a lot... i will likely be doing that today.
