94 accord. manual trans.. wont crank with key..
Alright so my car only cranks over if I bypass the starter... It Will also start if I push start it.. but if I try and turn it on with the ignition it Will not crank.. batterie is good.. need help..
I would start at the clutch pedal switch. See if the pedal is pushing that switch closed.
