94 EX AC warm at idle
Old May 13, 2011 | 03:51 PM
wietgr's Avatar
Default 94 EX AC warm at idle
94 EX 2.2L Vtec KA MT - My A/C is cold as can be when im on the highway, ut as soon as i get into stop and go traffic, at idle the air goes warm and the engine will stumble, bogging down as if its going to die then will jump back up to about 700 RPM. it will do this every 10 seconds or so, im sure its high pressure in the system but what could cause this?
Old May 13, 2011 | 04:41 PM
It could be the clutch plate gap is too large on the compressor. You will have to watch the clutch plate while the car is idling to see if it keeps spinning with the a/c compressor pulley.
If the plate starts and stops spinning, you will have to use a volt meter to see if the compressor is getting a constant 12V.
Do not add any R134a unless you have the pressures tested in the system.
drickman9
Oct 8, 2021 01:49 AM
snider
Jan 27, 2012 09:51 AM
sis00accord
Dec 19, 2011 12:27 AM
jimcmiller
Apr 5, 2010 08:54 PM
effdbmx1
Dec 26, 2009 06:34 PM
