94 lx with strange staling problems...
I have a 94 lx with the f22b2 in it, my problem is when coming to a stop the can will stall on me, same with keeping speed and turning left. If I turn right nothing happens but if I stop, even slowly the car will stall. I dont let the gas tank get below 1/8th if I can and it will stall on me even at half of a tank. someone throw me sugestions, I can't figure this one out..
thanks |
I have read about stalling when stopping on here, but don't have a good answer. When you find the solution please post it.
I would check for engine and transmission codes (if an automatic). See the common DIY threads on top of this forum for a link on checking engine codes. The other simple thing to try is to try shaking the key while the engine is running. If the engine stalls out, then your ignition switch is making poor contacts. |
the car used to be an auto but I have swaped a 5 speed in there now. nothing with the key/ignition contacts. someone help?!?
