95 4 cylinder & timing belt 180,000 miles
Hi, well coming up on 180,000 miles and the timing belt will need to be replaced soon. Will be getting it done at the dealer and was curious, since this is a big job is there anything else that can be done while they have it all apart to make it run better?
Just make sure they do the seals, water pump... Make it run better? I guess have them do the plugs, maybe the cap/rotor/wires? That will be a seperate charge though, because it really has nothing to do with the belts. It will help it run smoother.
Damon,not to scare you,but they are going to charge you BIG time.If you are able to afford it,it should be done correctly.But dont be suprised when the Bill is very high.I hope they dont try and sell you stuff ya stuff you dont need.
Get the quote first before dropping off.
The items related to the timing belt job that I would suggest are water pump, crank, cam and balance shaft seals, the tensioner bearing, accessory belts and the seals for the timing belt covers.
Saved myself $700-$1000 easily by doing it, and at 150K I will do it again.
Yes it is not a novice job, but not really hard at all to do. I have done just about everything on cars so I was not afraid to do it, besides I didn't have $1200 the throw at Honda. I have the tools and knew I could do it, I was going to go the lazy route till they told me the cost.
