95 accord power door locks again
OK I took passenger power lock actuator out and the rubber stops are in place. It cycles 2 times when I try to lock or unlock and does not move. the lever never moves on the actuator and the teeth are all on the gears. After disassembly I see a small spring which I assume is supposed to keep pressure to run the 2 pawls out???? Anybody go as far as taking the actuator all the way apart? I found a small square plastic piece broken and not sure from where?
If you search my posts, you'll find a post where I glued a wood chip to anchor the small spring in the actuator. The small plastic lug anchored the spring. Some pics were attached. I searched my files but I no longer have them.
The "repaired" actuator worked but not every time. Since it was LR door I lived w/ status. I no longer have the car.
I will have to say its a cheap setup, and why the clutch there? Any way I fixed it in a different way, I shot hard epoxy into the hole maybe 3/8 of and inch deep and after fighting to get it together it works great!
Antarctica
Oct 5, 2010 08:33 PM
abhanu
Mar 31, 2008 11:02 AM
