95 Accord V6 tranny issues.
I picked up a 95 Accord with a V6 for dirtcheap to drive for the winter. Its an auto, but the tranny is leaking. I haven't jacked it up yet (I've owned it for 2 hours) but I am just wondering if there is any known places where these things leak from. It does have 213k, but I picked it up for $200 with a pretty clean body, nearly mint interior, new brakes, and all I did was put some fluid in it and drove it home. Thanks.
Is it leaking oil or transmission fluid? Where is the leak coming from?
Originally Posted by PAhonda
(Post 194261)
I haven't heard too much about ATs leaking fluid. Try to locate the source of the leak.
I would inspect the drain plug to see if the seal is bad and around the sensors and solenoids. It is possible that there is a crack in the case somewhere. |
Also check around where the inner CV joint meets the Differential.
It could be that an axle has been replaced and there was a seal damaged going back together. |
