95 ex Honda Accord, sensors
i need to replace my VSS and crankshaft position sensor for my 95 accord ex (4cyl), is there a manual i can check out and find out where it is? is it at the DIY and which manual.
Thank you Neiser |
RE: 95 ex Honda Accord, sensors
There are 94-97 Accord manuals from hondahookup.com for download. See Online Manuals diy links.
What DTC's (trouble codes) have you downloaded? The VSS is behind the destributor on top of the trans very near the thermostat housing. I think the CPS is in the distributor (was on 94 Accord). If you have a CPS fault, the part is not available separately. Most replace distributor w/ used or rebuilt unit. There are diagnostics in the manual to confirm the CPS is defective (open or shorted). good luck |
Thank you very much! that helps alot.
Neiser |
