96 accord dead gages, no power windows, no clock
Old Sep 22, 2011 | 10:35 AM
cowboyup269's Avatar
Default 96 accord dead gages, no power windows, no clock
Hi all looking for a little help I have a 96 accord wagon. we lost the gages, power power windows and the shift lock. Fuses under hood are ok. Any other ideas?
thanks alot in advance
Jason
Old Sep 22, 2011 | 12:08 PM
bigpat's Avatar
Almost A Senior Member
The relay for the power windows is in the fusebox. Swap it with the cooling fan relay to see if that is the problem....Both relays are the same amps.
Old Sep 22, 2011 | 12:25 PM
The instrument gauges, power windows, and brake switch (e.g., related to transmission won't shift out of P) share common grounds G401 and G403.
Is it shift lock or clock, as your title states "clock" while your post states "shift lock"?
Attached Thumbnails 96 accord dead gages, no power windows, no clock-ground-401.jpg   96 accord dead gages, no power windows, no clock-ground-403.jpg
Old Sep 22, 2011 | 02:34 PM
Default redbull-1
the clock and the **** lock does not work
that 401 ground is it some where under the hood like above the master cyl?
i cant really tell from the pic you posted i cant get it much bigger then a stamp
thanks agin
Jason
Old Sep 22, 2011 | 02:48 PM
It seems like the forum reduced the size of pictures, it never did that before on the other pics I've attached. Ground 401 and 403 are located inside the cabin, underneath the dash areas. The pics are from the service manual, which you can download from the DIY sticky at the top of this forum.
Old Sep 22, 2011 | 02:53 PM
Let me try this again...
Lenno
Jan 29, 2012 07:45 PM
ohill1981
Jun 16, 2011 11:48 PM
pos85tempo
Dec 22, 2007 11:21 AM
th22ek9
Sep 13, 2006 11:11 PM
th22ek9
Sep 8, 2006 09:07 PM
