96 accord transmission.. HELP
Hello HAF. I have a 96 accord lx 4cyl a/t im currently experiencing weird stuff happening on the transmission when im at 20-25mph.
I drain and refill thr trans with honda atf 4times. Installed a magnetic filter and cleaned both solenoids. I don't knoe if I had this problem before I didn't notice it till just now. From Stop it shifts fine to any gears and at any speed, but when i slow down around 20-25mph i believe im at 2nd gear and when i press the gas pedal even with a light press the transmission immediately downshifts to 1st gear. Is this a sign of slippage? Or is it a solenoid problem? Maybe a TCU problem? I dont have any flashing lights or a CEL. I hope this is not a sign of my trans giving up anytime soon. I checked my fluid everytime and it is in its correct level. Help please. I dont know what to do to cure this. Thank, Dats |
Any work done on the transmission? Is the Check Engine Light on?
Shift quality can be modified by the throttle body -transmission feedback cable. You can download a shop manual from Online Manuals post in DIY forum to get the cable adjustment procedure. good luck |
No work done on the trans, just a drain and fill with honda dw1 atf.
No d4 lights nor CELs. I already adjustes the cable.. No improvement. It only happens when i'm slowing down 20-25mph then wheb i press the gas pedal to accelerate it downshifts from 2nd to 1st. |
