Sponsored by:
Sponsored by:
ABS Flashes Twice in Diagnostic mode, can't find what code that is
Old 05-03-2013, 06:17 PM
dlite922's Avatar
Question ABS Flashes Twice in Diagnostic mode, can't find what code that is
Hey guys,
New here, old to Hondas. I don't have a scanner so I jumped PINs 9 and 4 on OBDII port of a 2000 Accord 4 Cyl Sedan. (Could not find the double PIN blue connection under glove box in this car )
Thought this would be enough to show me a code but through this forum I found that some brake pedal action is required similar to resetting the SRS light (hold pedal in, turn on key, release pedal when ABS light goes off, press again when light comes back on, and finally release one last time when it goes off. What should flash next should be the ABS code)
However, the ABS light flashes twice and goes off until the car is driven past 10 MPH.
I could not find for the life of me what 2 slow flashes mean. That would be a code 20 but I searched on this form and none of the code lists have 20 in them.
Any clues?
Thanks experts,
Old 05-03-2013, 06:39 PM
I'll guess the code is 11, reading abs codes is a bit different.
11 is for the right/pass front wheel sensor.
Oiler1
04-20-2016 05:29 PM
Custnam
10-28-2012 12:50 PM
Abhishek719
11-27-2011 11:08 PM
jackfast
02-03-2009 08:33 PM
ddold@gkschools.org
01-29-2008 03:35 PM
Quick Reply: ABS Flashes Twice in Diagnostic mode, can't find what code that is
