-   -   96 lx starter (https://www.hondaaccordforum.com/forum/general-tech-help-7/96-lx-starter-45026/)
tanhanson94 Jan 18, 2012 09:31 AM
96 lx starter
so the starter is going bad in my accord. it will crank a little bit then it wont crank at all until i tap on the starter. any tips on replacing the starter???
iama_accord Jan 18, 2012 09:39 AM
Pretty simple replacement. Disconnect battery first (make sure you have the code for radio, if stock). Disconnect the wires going to the starter, should be 2 of them. Top bolt is a 14mm, and the bottom is 17mm. You're going to want to use a 6" extension on your ratchet for both bolts, makes things easier. Installation is in reverse, good luck. Oh and your battery tray might get in the way. I found it easier to take the battery out w/ the battery tray.
tanhanson94 Jan 18, 2012 10:50 AM
Is there anything else I need. Like to I need to jack my car up should I remove and install it from the top or bottom ?
PAhonda Jan 18, 2012 11:50 AM
The top bolt of the starter, you can access from the top of the car.
The bottom bolt was accessed from under the car. I had to use a few extension/socket combinations before I got the ratchet in a space where I could turn it.
It wasn't too bad to remove.
