97 Accord v6. Looking for relay?
Old Jun 1, 2022 | 12:46 PM
DoG Dragonslit's Avatar
Default 97 Accord v6. Looking for relay?
Hello, the Girlfriends 97 accord started clicking behind the glove box and I belive this is the culprit. Can't find my Haynes manual and I've looked online and can't seem to find a replacement or what it's for. Any info would be awesome! Thank you!
Old Jun 1, 2022 | 05:30 PM
Can you tell us the wire colors going to it?
Old Jun 2, 2022 | 12:08 PM
there is 2 both with the irange connectors but I belive the one with the red zip tye is the one going out. So blue.white. yellow/green. Black. And white/black. I can reasseble if needed.
Old Jun 2, 2022 | 03:07 PM
The two wire harness are for the ABS rear fail-safe relay and the ABS front fail-safe relay. Sometimes the clicking of relays is due to a loose ground wire. Check the ground wire on the harness going to Ground G403 first.
They are both Mitsuba Rc-2201 relays, Honda part no. 39797-SE0-004.
You may also want to swap the relays to see if issue is still there at that harness connector with the swapped relay.
Old Jun 2, 2022 | 04:27 PM
sweet thank you so much!!!
Old Jul 7, 2022 | 07:46 AM
Ok. So I've replaced both relays and tried lines to make sure everything is tight and connected. Still making the relays click... I'm at a loss here. Any other info would be great cause I'd like to see this as car b4 the end of summer.
Old Jul 7, 2022 | 10:07 PM
Are both relays clicking, or just one?
jbeebe
Aug 4, 2013 12:04 PM
yy0923
Jun 2, 2010 03:11 PM
ttwista
May 19, 2009 10:34 PM
SvrNScrN
Apr 5, 2009 03:11 PM
Ildiavolo
Feb 13, 2008 01:50 AM
