97 accord v6 power steering pump
Old Nov 14, 2014 | 09:08 PM
TexomaAccord's Avatar
Default 97 accord v6 power steering pump
My power steering pump is blowing ps fluid all out of the top of the cap, foamy, whining, etc --- And I'm thinking the o-rings need replaced on the inlet.
Does anyone happen to know the exact part number for the inlet o-ring?
I know I can buy an entire kit for 15.00 -- but I'm just wanting the inlet o-ring
Thankies
Old Nov 14, 2014 | 10:03 PM
hondapartsnow . com will give you the OEM part number
Old Nov 14, 2014 | 11:00 PM
Old Feb 13, 2015 | 12:00 PM
I replaced the pump itself, but its still whinning and groaning... ideas?
Old Feb 13, 2015 | 01:35 PM
Did you replace the o-rings?
Is the fluid still foaming up?
Is the PS pump new, rebuilt, aftermarket, etc...?
Old Feb 13, 2015 | 04:10 PM
reman'ed -- no, didn't replace any o-rings (had the tube already on the inlet) and fluid is still foaming
Old Feb 13, 2015 | 04:12 PM
Is there a screen in the reservoir tank that may be dirty?
Old Feb 13, 2015 | 04:37 PM
If you still are getting foam, then air is entering the system somewhere. You may have received a defective reman'd pump.
Old Feb 13, 2015 | 06:18 PM
funny story.. Just went out to drain the tank, unhooked the outlet tube and had the cap off... started the car and fluid just gushed out of the top of the tank... I cleaned it up... it had some fluid still in there so i started it... and no more whining or bubbling
Old Feb 16, 2015 | 03:58 PM
There IS a screen inside the PS reservoir. Down low, it's normally submerged in fluid.
If that is dirty & plugged up, then the suction side of the pump is pulling against that & causing more of a vacuum situation at the suction hose.
So it sounds like the problem is resolved anyway?? Not sure I understand how that fixed it, but glad its fixed.
