-   -   98 accord ex trans problems plz help (https://www.hondaaccordforum.com/forum/general-tech-help-7/98-accord-ex-trans-problems-plz-help-35180/)
hondaguy06 Sep 26, 2010 10:16 PM
I have a 98 accord that the auto trans is slipping something terrible.. i was just going to replace it but i saw the prices of used transmissions.. I found a 96 accord auto whole car wrecked in the rear for about 300 less than a 98 trans.. I was wondering how bad the swap would be for the trans? and what all would have to be changed.. harness..ecu what? Or if someone knows where theres a cheap 98 trans at that would be great... Thanks for the help
g22cd5 Sep 26, 2010 10:29 PM
it should be a easy swap. the 98-03 accords are known for auto trans failure if you didn't know. Me personally I would stay away from them. But I understand sometimes it just can’t be avoided. I would personally look into a 5speed accord or a 5speed swap if you can have the down time for the swap.
hondaguy06 Sep 26, 2010 10:57 PM
Yea i realized that but i came across the car cheap... and you dont think there will be any big problems that will have to be modded? for the 96 swap into the 98? and I am also checking into the 5spd swap.. waitin on a guy to email me and let me know if he still has the parts... O and you have any suggestions on how to get the drivers door open? Is stuck shut and i have the door panel pulled back and can see the handle is working and it appears to be unlocked.. you can hear it unlocking.. and the door still wont open.. and the door latch bolts in the jam so you cant take it out from inside the door.. and dont know how else to go about the problem?
JimBlake Sep 27, 2010 07:07 AM
First, I'm not much of an expert on auto-trannys.
But I think beginning in 1998 the whole way the engine ECU and the trans TCU talk to one another is completely different. For example the 96 trans will expect a physical cable from the throttle body down to the trans. In 1998 that's done with software.
So you might have to use the 1996 engine, ECU, TCU, wiring harness & everything. Lots of work & you probably don't want to downsize your engine from 2.3 down to 2.2...
hondaguy06 Sep 28, 2010 12:39 AM
hey thanks for all the help
g22cd5 Sep 28, 2010 09:30 PM
Ahhh very good point Jim I didn't take that into consideration. So yes it might be little more complicated the I organdy thought Sorry to the OP. So at the point it might actually be easier to swap to 5speed so then you won’t have the wiring harness issues.
As for your door see if you can’t get a flat head screw driver around the latch while someone tries to open the door. Might just be suck and needs a little help. Or if you don't mind tryin...try some WD40 see if that will help loosen her up to open. It sounds like its bound shut and needs some force to open her. But I can't say for sure since I can’t see it. I had thos prob with my rear door but it ended up being the child safety was broke so I removed it completely and it solved the prob. I'm sure you front driver door
hondaguy06 Sep 29, 2010 07:29 AM
Hey thanks for the help... ill have to give that a try.. ive been tryin to open it with a flat head on the inside through the door panel but no luck yet.. ill try and lube it up and see what happens
thepainter Sep 30, 2010 08:09 AM
ive been triin to figure out the same thing with my wifes 99 accord. ive been told that the 96 wont work because the 98 has a seperate computer for the tranny where as the 96 doesnt. if i find any more info in my search i will pass it on to u. oh ya i have put 2 USED 99 trannys in my wifes but the keep takin a crap and its gettin to expensive. so i would recommend a rebuilt if u stick with that tranny
hondaguy06 Oct 2, 2010 06:32 AM
Hey thanks and ill do the same for you!
JimBlake Oct 3, 2010 09:11 AM
Actually, beginning in 1998 the engine computer & the trans computer were combined into the same case, called a Powertrain Control Module (PCM). Before that they were separate units.
