-   -   98 Accord- instrument panel lights and tail lights NOT WORKING (https://www.hondaaccordforum.com/forum/general-tech-help-7/98-accord-instrument-panel-lights-tail-lights-not-working-42879/)
naimperez Sep 19, 2011 02:42 PM
I have a 98 Honda Accord LX. The panel lights do not light up at night after turning the headlights on. I removed the component and replaced ALL the bulbs and still nothing. I bought new fuses and installed them correctly (lol) and the instrument panel still will not light up.
secondly, the tail lights do not come on even after I replaced ALL the bulbs back there. the break lights work fine. not sure what to do next. i checked the connections and they seem fine.
PAhonda Sep 19, 2011 05:50 PM
I think that you are going to need a volt meter and a shop manual. I got a shop manual for my TSX from automanualsource.com for $22 and it has all that information about wire colors, etc...
Then you will have to start at a convenient place for electrical testing. I would start at the tail light bulbs that are not working to see if you are missing voltage on the + wire or ground. Then you will have to work backwards to figure out where the circuit is failing.
poorman212 Sep 19, 2011 08:29 PM
For the cluster lights, when you get to those, I'd start with the dash dimmer.
naimperez Sep 20, 2011 09:29 AM
thank you both. i'll get on that and see where it takes me
piggylover1985 Sep 20, 2011 04:11 PM
Are the climate control lights working ?
Murrsive Oct 2, 2011 07:01 PM
ditto
I have the same problem except my tailights work, to fix the tailights i think mine was a fuse on the passenger side, be sure to check fuses with a test light, sometimes the fuse will be blown but still look ok.
