98 accord lx check engine light
my check engine light came on in my 98 accord and i was gonna use the obd sensor plug to pull up the error code but the plug isnt in the bracket thats just under the drivers dash. does anyone know where it would be if its not where its supposed to be?
RE: 98 accord lx check engine light
your car is OBD2 ,the plug to chk for codes is under dash left side but u need a scan tool ....take car to the nearest Autozone they will chk the code for u for free .......then post it here ...
mine came on and took it to the dealer, it was $342.00 for new oxygen sensor
The Man has got the plan...Take to AutoZone for a FREE $80.00 scan...I cant believe that someone would pay $ 300.00 and some dollars to have a O2 sensor changed,./';][ That's called Highway Robbery. WheelBrokerAng:eek: ORIGINAL: deserthonda your car is OBD2 ,the plug to chk for codes is under dash left side but u need a scan tool ....take car to the nearest Autozone they will chk the code for u for free .......then post it here ... |
okay maybe i wasnt specific enough. i apologize. i know where my obd II is supposed to be located. the problem is its not where its supposed to be located. i found the bracket that its supposed to be mounted in and its not there. the reason i need to know is i can get the codes myself without auto zone by using a jumper wire in the obd II. but since the obd II is not where its supposed to be i cant do it. so does anyone know where it would be if it is not under the drivers console like its supposed to be??
I checked online at honda owner's link, the oxygen sensor is exspenive for sure. The part was $254.00 alone.
the rest were taxes and labor. |
if you disconect the battery for 1 minute and conected back the computer will reset again by itself
ORIGINAL: sk8mistro84010 okay maybe i wasnt specific enough. i apologize. i know where my obd II is supposed to be located. the problem is its not where its supposed to be located. i found the bracket that its supposed to be mounted in and its not there. the reason i need to know is i can get the codes myself without auto zone by using a jumper wire in the obd II. but since the obd II is not where its supposed to be i cant do it. so does anyone know where it would be if it is not under the drivers console like its supposed to be?? good luck |
Someone probably disconnected the service check connector from the bracket and pushed it back under the dash. You may have to pull the glove box out, but I bet it's close by. It's a blue connector in most cases. good luck But yes I've seen the DLC be shoved out of it's bracket and stuffed somewhere else. |
I know that 98 is the new generation and all that but in my 97 the port is behind the ash tray. Have you looked there just to be sure?
| All times are GMT -5. The time now is 12:53 AM. |
