99 Accord a/c control panel problem
Old Apr 5, 2008 | 08:13 PM
caboose
Default 99 Accord a/c control panel problem
I have an a/c control panel that was intermittent when turning the a/c **** on. When the a/c **** was operational, the a/c put out cold air. The blower or fan switch still works every time, but now the a/c control is dead. I feel like the problem is in the control panel. I have checked fuses and all are ok; any ideas on beginning my troubleshooting? Thanks in advance.
Old Apr 5, 2008 | 10:29 PM
hondadude's Avatar
Default RE: 99 Accord a/c control panel problem
Maybe you can get a code to display, try this link;
http://img183.imageshack.us/my.php?i...modetstgy1.gif
Old Apr 6, 2008 | 10:49 AM
caboose
I don't have the "climate control" type. My a/c is the cheap one with the blower ****, a/c, recirc, etc. The a/c and recirc is dead, but the blower switch has power.
Thanks for the response..
Old Apr 6, 2008 | 12:54 PM
hondadude's Avatar
DX? LX? EX?
Old Apr 6, 2008 | 01:30 PM
Chiovnidca's Avatar
Is the **** broken?
Old Apr 7, 2008 | 04:19 PM
caboose
DX, no the **** isn't broken and I didn't fall off a turnip truck...ha.
I'm ready to pull the panel out and check for loose wiring and to see if I'm getting voltage to the a/c or recirc switch.
Where can I get an electrical diagram of the a/c control panel?
thanks,
caboose
Old Apr 12, 2008 | 12:35 PM
caboose
Any wiring diagrams of the a/c control out there?? thx..it's HOT..
Old Apr 24, 2008 | 09:07 PM
caboose
Still no luck in solving my problem----is there a relay that supplies power to the a/c, recirc control panel??? Thanks in advance for your help.. this power is intermittent; sometimes the panel will illuminate when the key is turned on, but then the power to the panel goes away..
Old Oct 29, 2008 | 03:03 PM
sgriek
I took my 99 accord in for a similar issue. He says the control panel is bad, but there is no telling if there is something else bad also. He said the control unit is also causing the radiator fan to never come on which resulted in it overheating. This doesn't make sense to me becuase I would think that the engine cooling system should be completely separate from the a/c system. Did you replace the unit? Did it solve the isssue?Did you notice your radiator fan not working when this panel was bad?
Cun0144
Aug 5, 2010 11:50 AM
Cun0144
Aug 5, 2010 12:54 AM
spezticle
Mar 20, 2009 03:26 AM
mwest
May 14, 2008 09:51 AM
caboose
May 6, 2008 06:39 PM
