ABS connector?
Can some one send me a pic of the connector I need to short to get the ABScodes for a 94 Accord EX?A two wire connector onder the glove box. I removed the glove box and still don't see any two wire connector.Thanks
RE: ABS connector?
This link should help. In the future, you don't have to remove the glove box to get to the connector.
http://www.dhost.info/accordinfo/howto/cel.html |
RE: ABS connector?
PA Honda thanks for the info is grea; however , Im looking for the connector for the "ABS" I neet to pull the ABS codes; the ABS light is the one that come about two or three minutes after the car been driving. Probably is one of those.
RE: ABS connector?
Same connector causes the ABS light to flash when keyswitch is on. Flash code is slightly different. All short flashes after a 2-second alert flash. So ffff-ffff = 4-4, rear wheel sensor.
good luck |
RE: ABS connector?
TexasHonda thanks for the help I really appreciate.
